05-11-2021 11:06 AM
At 11:00am PDT today, the Wi-Fi Alliance announced a new Wi-Fi security vulnerability, FragAttacks.
The FragAttacks - RUCKUS Technical Support Response Center is our central web page that brings together all of the RUCKUS-related information you need to address FragAttacks, including:
In addition, the RUCKUS senior technology leadership has prepared resources to explain the nature and impact of the FragAttacks vulnerabilities, including technical blogs, videos, and podcasts. These are all linked on the FragAttacks - RUCKUS Technical Support Response Center web page.
Please use this thread as a central location for your FragAttacks questions and concerns. Doing so will help to ensure that we can respond as quickly as possible to your issues as you raise them.
Thank you!
Allan Grohe
05-17-2021 02:13 PM
Just to clarify, because the FragAttacks report is really that complex and complicated. The report contains 12 distinct vulnerabilities and some are targeted at APs, some are at clients, and some are at both. To prevent all 12 CVE's contained in the report, both APs and client devices need to be patched. Patching just the APs will prevent some of the vulnerabilities, but not all of them. It will, however, reduce the attack vectors available, especially with older client devices that might not get patched thanks to a lot of different factors.
For those critical networks, refer to this page from the support site for additional help https://www.commscope.com/fragattacks-commscope-ruckus-resource-center/wifi-fragattacks-what-you-nee...
For those who want to get even more into the attacks, you can also check out this post-https://jimswirelessworld.wordpress.com/2021/05/11/fragattacks-just-reinforces-the-it-depends-complexity-of-wi-fi/
05-18-2021 02:53 PM
Just FYI, as informed by syamantak_omer, I could upgrade the ZD even if I don't have support entitlement. Just download the img file, then upgrade. Mine automatically given 30 days Support after the upgrade.
Or contact Support where they'll give grace period support file to upload to ZD.
05-18-2021 02:56 PM
Hi @hendri_marzuki ,
Thanks for the feedback and good to know that you were able to upgrade your ZD.
05-18-2021 03:06 PM
Thanks! I just hoping there will be patch for ZD1100, as the latest FW is version 9.10.2.0.130.
Another thing, we still have ZF7363 in operations which make it difficult to upgrade to FW 10 that has the patch. Finger crossed.....
05-18-2021 08:20 AM
Hi All,
Fix for Unleashed 200.7 has been released on our support site.
For different AP models, Unleashed 200.7.10.202.127 MR6 software images can be found on below link.
https://support.ruckuswireless.com/software?query=200.7.10.202.127
Our FragAttacks support page also updated with this information.
https://support.ruckuswireless.com/fragattacks-ruckus-technical-support-response-center
