02-24-2023 11:36 PM
We are currently using Rcksu equipment in the field.
There is a persistent loss of communication, and I checked the controller log.
■ List of equipment used
Smartzone 100
ve5.2.1.0.515
Ruckus R310
ve5.2.1.0.698
Client [XXXXXXXXXXXX] disconnected from WLAN [OHT-5G] on AP [OHT-AP-09@XX:XX:XX:XX:XX:XX] due to inactivity.
I am contacting you because I believe the loss of communication is related to the due to inactivity. log.
Why do these logs occur?
What is the solution?
03-30-2023 01:11 AM
Hi .Ayushi_Try Party
Change the configuration to 600 seconds and the monitoring results in the client disconnecting.
The WLAN authentication method uses WPA2-PSK.
02-27-2023 04:58 PM
Hello.
I am unable to enter the site at this time.
We will visit the site and contact you again after confirming and setting up.
Thank you for your answer.
good job for today.
