02-24-2023 11:36 PM
We are currently using Rcksu equipment in the field.
There is a persistent loss of communication, and I checked the controller log.
■ List of equipment used
Smartzone 100
ve5.2.1.0.515
Ruckus R310
ve5.2.1.0.698
Client [XXXXXXXXXXXX] disconnected from WLAN [OHT-5G] on AP [OHT-AP-09@XX:XX:XX:XX:XX:XX] due to inactivity.
I am contacting you because I believe the loss of communication is related to the due to inactivity. log.
Why do these logs occur?
What is the solution?
02-25-2023 01:42 AM
Hello @CHOIYOUNGJAE
Could you please confirm if any specific type of client devices(Mobile, laptop, scanners) getting disconnected from WLAN due to inactivity timeout or all the device are getting impacted.
Please check the inactivity timeout value in SmartZone under the WLAN configuration > Advance options.
If it is set to default 120sec please increase the timeout value and set to 600sec.
03-12-2023 11:00 PM
Hello, Ayush_Tripati.
The current setting is 120 seconds and has been changed to 600 seconds.
Checking the logs invalidates the timeout-related logs and disconnects the client.
How many days should I monitor after changing it to 600 seconds?
03-13-2023 10:02 AM
Hello @CHOIYOUNGJAE
Could you please confirm if clients still getting disconnected due to inactivity timeout after increasing the value.
What is the WLAN authentication type ? Any specific type of devices getting disconnected or all the devices ?
03-13-2023 11:07 PM
Hi Ayushi_Tree party
I will monitor that for about 7 days.
The WLAN authentication type is using WAP2.
A particular type of device that loses connectivity is a wireless LAN card called the FXE3000.
