Working Wispr portal example
harald_thomas_c
Hi all,
is there any working wispr portal example available?
TIA
Harald
8 REPLIES 8
Sorry for the late response, here are the Hotspot WISPr Reference Guide for 5.2.1.
For SZ300/vSZ-H:
https://support.ruckuswireless.com/documents/3336-smartzone-5-2-1-ga-hotspot-wispr-reference-guide-s...
For SZ100/vSZ-E:
https://support.ruckuswireless.com/documents/3331-smartzone-5-2-1-ga-hotspot-wispr-reference-guide-s...
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
thx, i'll give it a try.
Understanding the logical workflow of authentication in a WISPr portal will help you get it working....
1. Client connects to WISPr WLAN unauthenticated.  Client is only allowed the whitelist.  Client gets redirected to the webpage by the SZ.  The SZ provides several parameters (client information) to the webpage in the redirection (examine the URL on the client when redirected and you will see it).
2.  The webpage(s) post an authentication request to the SZ - also providing paramaters (some are the parameters it received).
3.  The SZ uses the information to send a RADIUS request (can be internal or external AAA you define).
4.  RADIUS responds with accept or deny to the controller and the controller changes the client status to reflect this.  The SZ presents the authentication request with a reply (completing the WISPr webpage authentication request).
harald_thomas_c
i got the wispr portal running with username and password.
is there any way to use the wispr portal as a 1 click portal without username and password?
as a workaround i have the username and password field hidden with prefilled username and password.
