11-15-2020 10:29 PM
Hi all,
is there any working wispr portal example available?
TIA
Harald
11-16-2020 01:01 AM
You can use any wispr solution. WE used at least 3 different portals, all worked just fine.
11-16-2020 03:55 AM
Hi Harald,
v/SZ newer version has internal WISPr portal, you can use it for a quick demo.
11-23-2020 12:08 AM
Not exactly what I want.
I want to develop a customized Wispr Portal on a linux server to be used with the smartzone.
11-25-2020 12:11 PM
vSZ documentation has code example for Wispr portal, including details of manipulations of user access.
I am not awear about any WISPR portal embedded in the vSZ. Actually, as much as I know there is no such thing (at least in v. 5.2). There is the guest portal, but it is quit different thing.
As there are a lot of developed WISPR portals are available, writing another one doesn't make very much sense, from practical point of view it would be better to use and customize some standard solution, which is supported and is under constant development.
Different case, if you do it as hobby, or to learn technology, than it is very much justified. Otherwise using, for example, Packetfence makes more sense.
Hope it helps.
