08-04-2021 12:03 PM
Hi, I have a SmartZone 104, I want to tunnel my WLAN with RGRE but when I enable it the AP doesnt broadcast the SSID. I have checked logs and it says "610 AP tunnel disconnected, AP disconnected from data plane []. Reason: [no remote peer available]."
I have entered the VLAN ID under advanced options and enabled Tunnel traffic through ruckus GRE
Any help please?
08-04-2021 12:27 PM
Hi Zubair,
Did you configure SZ in dual port setting or single?
Check if AP can reach DP IP address (if it is two port setup).
