Export WLAN configuration to another SmartZone
philip_francis1
Contributor
Hello, I want to export my WLAN configuration to another SmartZone that is not part of the same cluster. We are doing a brand new build and I need dupicate WLAN configuration.
Is there any way to export the entire WLAN configuration of one Smartzone in to another ?
-or do I have to manually replicate it ?
1 REPLY 1
syamantakomer
Community Admin
Community Admin
Hi Philip,
As of latest SZ version 5.2.1, exporting WLAN configuration from one SZ cluster to another is not supported.
If you want same configuration, then you can pull the configuration backup from the source SZ and upload it to the desired SZ.
Syamantak Omer
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
