12-09-2020 11:00 AM
I have a vSZ-H and a physical data plane appliance with a tunneled SSID configured. SSID works fine however, trying to do WebAuth so it gives a certificate error. Installed the 3rd party valid SSL cert (wild card) and still getting an error in the browser. Viewing the certificate it shows, it is still using the Ruckus cert and not the wild card cert that was installed.
Mapped all the services to this cert and here is how it looks like under the SZ as a Server Certificate. What else is missing?
12-10-2020 08:47 AM
So you mean when I generate the csr under common name I use the IP of the vSZ-H?
12-10-2020 07:54 AM
Here is the screenshot for more help.
Please make sure you hit "Ok" to apply the changes.
12-10-2020 08:37 AM
Yes that is how mine is setup.
12-10-2020 08:48 AM
Try to reimport the cert as I have suggested in my previous comment.
12-10-2020 09:34 AM
Can you confirm what did you mean by the IP in the common name? Did you mean when generating the csr I use the IP of the vSZ?
Also since there is a physical data plane appliance involved and there are two vSZ nodes do I have to use the same cert for Intra Device Communication?
