02-24-2023 08:11 AM
My Ruckus switch installed in my Lennar home is working for wireless connection, but the speed is lower than I'd like. I do have wired connections available but they do not light up when plugged into the switch. Is there a way to get these connections online?
Thank you
02-24-2023 01:49 PM
Hi vrizzo
Thank you for the response and update.
Please check the port number. And also try the Telnet option.
SSH- 22
Telnet - 23
If SSH or Telnet works, please login with default credentials with the combination as shown below:
If telnet access/ssh access is not working sometimes a hard reboot (disconnect and connect the switch from the power outlet) works, but if that does not work, we need to access via the console as described in step number ‘4’ of the previous post.
And also, you could try the WEB access option as described in Point ‘3’ option II.
Try to access your switch from a web browser by pasting the below URL.
https://192.168.1.66 or http://192.168.1.66
If this step does not work, we need to access the Switch via the Console as mentioned above (step number ‘4’ of the previous post)
Lennar Home Community.
02-24-2023 09:16 AM
Hi vrizzo
Hope you are doing well!!!
From the case description, I could understand that you are getting lower speeds from the ICX-7150-C12P Switch. And also wired devices are not powering up.
We suggest you confirm the speed transmitted by your Internet Service Provider (ISP). You could check the ISP connectivity from the Router, maybe with Local Router Wi-Fi or by an Ethernet cable from the Router a laptop, or a PC. (Please refer to the below pictures). Please compare the speed tests from the ISP Router and from the Switch. And also, please share the screenshots of both results.
Could you also please let us know?
Please refer to the below guide as a reference for the connection setup:
02-24-2023 10:56 AM
My ISP is AT&T. I've connected to the WiFi direct to the router. I am not able to send screenshots in this chat, but the speed is 351.0Mbps. Once I connect to the WiFi from the switch (Lennar-XXXXXXXX), the speed increases to 520.0 Mbps...but the performance is slower and frequently drops and says I don't have access to the internet. I then connected with my ethernet and the speed increased to 1.0 Gbps, but it says I have no internet access.
As for the switch, the ethernet cable is connected to one of the 12 ports. I have tried changing the port, but I still do not see a green light like I do for the other connections. I have had this installation for over 2 years, but this is the first time I am trying wired connections.
Victor Rizzo
02-24-2023 11:14 AM
I have tried to diagnose the issue with the ethernet cable connection and Windows has found a problem. This is verbiage from the issue:
"Your computer appears to be correctly configured, but the device or resource (DNS server) is not responding".
Do you have any advice on how to resolve this?
Thank you,
Victor
02-24-2023 11:51 AM
Hi vrizzo
As you have slow performance, connectivity issues and it drops frequently.
This issue may happen when the Switch starts running on the Routing code. The Switch should run on the Switching code to avoid these issues for Lennar home users. Due to a power outage, the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
Please follow the description and steps to get this issue resolved:
You can take Console access to the switch in order to verify, if the switch is able to connect properly to Access Points or if it has a ‘Routing Code’ issue which happens due to power outages most of the time, this is a known issue for Lennar home users.
-MAC address: Physical address of the device this never changes
- An IP address is a unique address (logical) that identifies a device on the internet or a local network like your home (this can change and may not be the same as the one shown on the dashboard)
Please follow the below steps:
ICX7150-C12 Router>
show version
copy flash flash secondary
(Please share the output screenshot of the ‘show version’ command)
Example:
There are Two ways to fix this issue:
I) How to Fix Routing code issues on Lennar Home users via CLI
II) Or WEB access option
Once you are logged in to the ICX-7150-C12P please follow and perform the commands same as shown in the step that are on point '3'
