02-24-2023 08:11 AM
My Ruckus switch installed in my Lennar home is working for wireless connection, but the speed is lower than I'd like. I do have wired connections available but they do not light up when plugged into the switch. Is there a way to get these connections online?
Thank you
02-24-2023 01:49 PM
Hi vrizzo
Thank you for the response and update.
Please check the port number. And also try the Telnet option.
SSH- 22
Telnet - 23
If SSH or Telnet works, please login with default credentials with the combination as shown below:
If telnet access/ssh access is not working sometimes a hard reboot (disconnect and connect the switch from the power outlet) works, but if that does not work, we need to access via the console as described in step number ‘4’ of the previous post.
And also, you could try the WEB access option as described in Point ‘3’ option II.
Try to access your switch from a web browser by pasting the below URL.
https://192.168.1.66 or http://192.168.1.66
If this step does not work, we need to access the Switch via the Console as mentioned above (step number ‘4’ of the previous post)
Lennar Home Community.
02-24-2023 12:58 PM
Hi Imran,
Thank you for your feedback, but I am having a little trouble with PuTTY. I have found my IP address (192.168.1.66) for the switch (ICX 7150-C12). When I open PuTTY it says "specify the destination you want to connect to". For this I typed in the IP address above with connection type selected "SSH". I then clicked "Open" and it brings up what looks like the command line but throws an error saying "Network Error: connection refused". I am not sure what to do next. Please advise, and thank you for all your help so far.
Victor
02-24-2023 01:49 PM
Hi vrizzo
SSH- 22
Telnet - 23
02-25-2023 03:00 PM
Thank you for your help! I am good to go!
02-27-2023 08:07 AM
Hi vrizzo
Great!!!
Good to know that the issue is now resolved.
Have a great week ahead!!!
Thank you again for contacting RUCKUS Lennar Home Community
