WiFi inconsistent, internet speed go hi and low. Forgot id and password.
LD
so there was a power outage day before yesterday. Than yesterday WiFi signal becomes interrupted every other second. Internet is fine but WiFi is flaky and slow. I want to login into unleash app but forgot id and password. Plz help
32 REPLIES 32
I just wanted to confirm that after reset will log into the Switch dashboard and try default login credentials and then what should be the next steps.
Also how much time and steps will take to rerun the ruckus. Worried that WiFi access will not be available.
Hello @LD ,
Once the reset is completed, you will be able to login to the Switch with default credentials.
Once the switch dashboard is accessed, we can check the configuration of the Switch and confirm if the Switch is running on Switching code or Routing code and will assist you accordingly.
Also, could you please confirm if you have access to a Windows laptop?
Hi, no we do not have access to Windows laptop.
Hello @LD ,
Hello @LD ,
