01-19-2023 12:06 PM
Good afternoon,
I contacted customer support, advised to post here and someone would reach out to help. My WIFI barely works if it works at all since the power outage. I have tried the usual unplug to reset but no change. Cell phone wont connect, TV WIFI connects but extremely slow (I have 1tb ATT Fiber).
Andrew Battaglia - (209) 329-3632
01-19-2023 12:46 PM
Hi @AndrewB
According to your description, seems the Switch is booting from the incorrect partition after the power outage causing the connection issues, Please follow up the guide to fix the issue.
Guide#1 for CLI:
Guide#2 for CLI:
Note: if you have access to the Unleashed Dashboard and the Switch can be seen from there, it may look like the following image, ICX7150-C12-Router instead of ICX7150-C12-Switch, now before starting the steps of the guide, I will advise you to cable the computer directly to the Switch, since you will have a better connectivity than if you connect via wireless.
Upgrade a switch via Web GUI (ICX7150 Switch)
01-19-2023 02:13 PM
Hi @AndrewB
Please try the same as the unleashed Login APP
Most common usernames and passwords
Username : super password: sp-admin
username : admin password : Lennar
username : admin password : Ruckus1
username : admin password : Ruckus!
username : admin password : lennar
-This is key sensitive make sure to have the capital letters
-Please try telnet option
Best Regards
Fernando Vasquez
01-20-2023 12:04 PM
I have the same Problem, none of the username admin combinations work, I tried everything capital/normal letters, I can't get access. I need help to access the switch do hopefully get the resolved.
By the way, why is a power outage causing so many problems? can this be avoided somehow?
01-21-2023 02:07 PM
Hi! For me the below worked.
admin
Lennar
01-23-2023 11:54 AM
Hi @AndrewB
We are glad that it worked for you.
Yarenis Hernández.
Technical Support Engineer | L2 TAC Wired | Lennar Home Community Moderator
01-23-2023 11:54 AM
Hi @slaba0815
Please open a new post for better assistance.
Yarenis Hernández.
