12-06-2022 10:43 AM
My wireless APs lost power this morning so I tried to perform a factory reset. However the lights on the switch keep flashing after reset.
If I unplug the power and plug back in, the flashing stops, but does not resolve my issue with the wireless APs.
Please suggest what else I can try.
12-06-2022 11:02 AM
Hi @jason_pinto
Just to confirm does the Access Points are the only devices not getting power from the Switch or any devices are responding, if none devices are getting power from the switch, and the SYS light in the Switch is orange or amber, the unit may be stuck in boot mode, so in order to fix it, you need to get access via console, using two connections one is for console access using the USB to type C cable (the USB will be connected on your computer and the type C on your ICX7150 Switch) now the second connection will be an Ethernet cable from your computer to the out-of-band port on your ICX 7150 Switch),don't worry the next guide explains the port locations and there are pictures about it.
Ruckus ICX Recovery Load boot code from boot monitor Tutorial video
Yarenis Hernández
12-06-2022 10:32 PM
I managed to do a software recovery and it works now.
12-07-2022 08:06 AM - edited 12-07-2022 08:07 AM
I am glad that it works.
Yarenis Hernández
