01-01-2023 10:06 PM
New home was outfitted with Ruckus switch and 2 AP. I was able to reset and get the 2 APs working. The Switch on the other hand will not let me log in with the posted default password or other common passwords (admin & sp-admin super & sp-admin admin & passoword). Those are the few I have tried. Any help would be appreciated.
01-02-2023 10:19 AM
Hi @home_auto
For your information the switch is working fine because the access points are working, please confirm how you are trying to gain access from switch through WebGUI, SSH, Telnet, console?
Note: Taking consideration that the unleashed dashboard/ application have their own credentials and to manage the access points and the switch has other credentials to manage the switch.
These are the credentials for the switch.
Usernames: Passwords:
admin sp-admin
super Lennar
lennar
ruckus
Ruckus!
Ruckus1
admin
password
Jayavidhya.
01-02-2023 05:37 PM
Hi Jayavidhya,
I tried the set of username and passwords you sent along with a few other combinations and still unable to get access. Do you have any other suggestions?
01-03-2023 07:14 AM
Hi @home_auto
Please try gaining access to switch via console and through CLI/console to perform a password recovery. After you have done with the password recovery you can fix the routing code issue.
Please follow the below guide to perform password recovery.
Password Recovery on a Ruckus ICX Tutorial video
https://www.youtube.com/watch?v=XJS28DWbHM4
Recovery Process
1. Console access to the switch.
2. Reboot the switch with the console cable attached and press "b" until the following is displayed.
3. Using the following commands to remove the password
4. Set new password commands.
Enable
config t
username super password pass
Where super is the username and pass is the password
Wr mem
exit
Reload
Are you sure? (enter 'y' or 'n'): y
01-05-2023 10:59 PM
This was helpful thank you. I made it to step 3. While it was checking the POE info, it ran into TFTP session timed out.
