06-11-2023 07:43 AM
None of the APs (4) are receiving signal from the switch.
06-16-2023 08:24 AM
Imran: I'm getting ready to download the software to kick things off... I'll let you know how it goes.
06-16-2023 09:53 AM
Hi @Silverbullet
Thank you for the update.
Sure, please do let us know if there is any help required on the troubleshooting steps or if you are stuck at any point. We are happy to help you.
06-16-2023 10:38 AM
I've downloaded everything and made changes to the com port but not able to get past the putty screen with the green cursor.
06-16-2023 11:08 AM
Hi @Silverbullet
Did you try a reset of the Switch with a paper clip MULTIPLE times?
If yes, Please share a picture showing the cable connections between the Switch and the Laptop/PC for performing software recovery and also share a screenshot of the error you are getting on Putty.
Please let me know if you have any further queries in this regard.
06-16-2023 11:57 AM
