06-11-2023 07:43 AM
None of the APs (4) are receiving signal from the switch.
06-20-2023 08:31 AM
Hi Imran: I sent you a video last night; I might have to send you another one later today. I also wanted to remind you that the switch I have is a replacement (remanufactured by Ruckus) that replaced the original switch I had. Therefore, I am very familiar with putty and how to get into the ruckus etc. It's just not happening. I actually tried numerous times last night... I have also tried the paper clip and power route countless times without success. Cheers!
06-20-2023 10:33 AM
Hi @Silverbullet
Thank you for the response and for sharing the requested information.
Based on the troubleshooting done, you confirmed, and we saw that after the reset, booting up the Switch, and trying the software recovery process multiple times, the failure persists. And the management port is not responding. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
Thank you again. We appreciate your patience and cooperation.
06-14-2023 07:07 AM
If in fact this is a power problem, why didn't someone recommend installing a UPS?
06-14-2023 08:45 AM
Hi @Silverbullet
Apologies, Effective November’2022, ‘Ruckus Support for Lennar Homes customers will no longer be handled by phone or email. We will be exclusively supporting customers via this community forum support model only.
As you mentioned there are Amber and Green lights, If there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
First, we will try to reset the Switch as described below:
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES AS DESCRIBED ABOVE.
06-16-2023 08:22 AM
Hi @Silverbullet
Could you please let me know if you were able to resolve the issue with your Switch which is stuck on boot mode?
And we recommend getting help or suggestion from a technician regarding UPS.
Please let me know if you have any further queries in this regard.
