Switch not Sending signal (power) to APs. ICX 7150 C-12
Silverbullet
None of the APs (4) are receiving signal from the switch.
30 REPLIES 30
Imran:  I'm getting ready to download the software to kick things off... I'll let you know how it goes.
Hi @Silverbullet
Thank you for the update.
Sure, please do let us know if there is any help required on the troubleshooting steps or if you are stuck at any point. We are happy to help you.
I've downloaded everything and made changes to the com port but not able to get past the putty screen with the green cursor.
Hi @Silverbullet
Did you try a reset of the Switch with a paper clip MULTIPLE times?
If yes, Please share a picture showing the cable connections between the Switch and the Laptop/PC for performing software recovery and also share a screenshot of the error you are getting on Putty.
Please let me know if you have any further queries in this regard.
