11-16-2023 06:12 AM
After having left and returned to my previous internet provider, I am attempting to (re)connect to the Ruckus AP within my home. The network name and so on are different than I previously had but seemingly that previous network name is still housed within the Ruckus system/box and I no longer see the ‘Configure.me.xxxxxx’ listed in the Wi-Fi networks of my mobile devise to setup (reset up) the AP devices within my home. Has anyone else dealt with this and/or have a solution?
11-16-2023 12:47 PM
Hi @wilntracyjax
If that's the case, the best option here is to perform a factory reset of your Access points to be able to configure a new network from scratch.
NOTE:
If you have more than one Access Point (AP) in your house, please go to the Ruckus Switch (located in the panel) and disconnect from its ports the Ethernet cables of all the Access Points, except the one that you are going to work with.
Kind regards,
Sofia Gätjens
11-22-2023 01:23 PM
Hi @wilntracyjax
Sure, please check and let us know if any assistance is required.
Did we answer your query? If yes, hit the Kudos button and also accept the answer as an Accepted solution.
11-16-2023 09:00 AM - edited 11-16-2023 09:02 AM
Hi @wilntracyjax
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
Could you please check the link below and confirm that the setup you have is the correct one?
After confirming that the setup in your house is the correct one, please check if you are able to connect to your lennar wifi, if you still present issues please the following guide to reset the APs and configure the unleashed network from scratch:
Kind regards,
Sofia Gätjens
11-16-2023 09:38 AM
Hello @Sgatjens,
3. My ISP is operational, I can connect to internet and so (am doing so wirelessly) with other devises, (laptop, smart TVs, iPhones, IPad, etc.)
4. I have 2 AP connect to the switch. When powered the ‘PWR’ & ‘CTL’ lights are green. The ‘2.4g’, ‘5g’ & ‘AIR’ lights are Amber.
11-16-2023 09:40 AM
11-16-2023 09:41 AM
I was actually able to figure out adding a photo
