11-16-2023 06:12 AM
After having left and returned to my previous internet provider, I am attempting to (re)connect to the Ruckus AP within my home. The network name and so on are different than I previously had but seemingly that previous network name is still housed within the Ruckus system/box and I no longer see the ‘Configure.me.xxxxxx’ listed in the Wi-Fi networks of my mobile devise to setup (reset up) the AP devices within my home. Has anyone else dealt with this and/or have a solution?
11-16-2023 12:47 PM
Hi @wilntracyjax
If that's the case, the best option here is to perform a factory reset of your Access points to be able to configure a new network from scratch.
NOTE:
If you have more than one Access Point (AP) in your house, please go to the Ruckus Switch (located in the panel) and disconnect from its ports the Ethernet cables of all the Access Points, except the one that you are going to work with.
Kind regards,
Sofia Gätjens
11-22-2023 01:23 PM
Hi @wilntracyjax
Sure, please check and let us know if any assistance is required.
Did we answer your query? If yes, hit the Kudos button and also accept the answer as an Accepted solution.
11-16-2023 09:48 AM
Also, I have the cat5 from the router to the switch in port 4 as pictured here
11-16-2023 09:56 AM
Hi @wilntracyjax
Thank you very much for the information provided.
If you go to your WIFI settings, are you able to see your Unleashed wifi /ssid?
How are the lights on the access points? are they statics or blinking?
Kind regards,
Sofia Gätjens
11-16-2023 10:12 AM
When I go into my Wi-Fi settings on my phone I see the Ruckus network, however, it has our old (previous) name still assigned to it and I cannot change it. The lights on the access points are different. As seen in the following pictures. The weirdest part of this all is that I can actually connect my iPad, 2 iPhones to Ruckus at the previous (old) named Wi-Fi/ssid w/o entering a passwordFurthest from switch on 2nd floor
Closes to switch on same floor (basement)
11-16-2023 10:24 AM
Sorry, I forgot to mention, the lights are static
11-16-2023 11:53 AM
Hi @wilntracyjax
Thank you for the info provided.
Alright, got it. Do you possess the credentials to access the Ruckus WiFi? Do you have the password for connecting to it?
It's important to note that changing the Internet Service Provider (ISP) won't impact or alter the Ruckus WiFi, as the ISP is solely responsible for providing Internet access, and these two systems function independently.
Kind regards,
Sofia Gätjens
