Stuck on ICX switch is connecting, no wifi
jsun
also receiving this error: Unleashed system only supports ICX firmware version 08.0.90 or later.
I can’t connect to the access point on my Mac terminal it’s telling me that the flash command is not right. Also I can’t install on my work computer to connect through wire
1 ACCEPTED SOLUTION
Imran_ruckus
Community Manager
Community Manager
Hi @jsun
As I see from the picture you shared, seems like the ethernet cable which is coming from the Router or Modem/Router combo is plugged into the wrong port on the Switch panel. It must be plugged into any 1 in-12 ports as shown in the below screenshot. Please unplug the ethernet cable and plug it into the correct port and try again. If requires please reboot (unplug and plug from the power outlet) your Switch and ISP (Internet Service Provider) Router once.
21 REPLIES 21
Chandini
RUCKUS Team Member
Hi Jsun
Thank you for reaching us
  • Could you please let me know if you are from Lennar Homes ?
Could you please try to connect to the switch using console and share the below outputs.
Link to connect to switch using console:
Execute the below commands once you have access:
  • Show version
  • Show flash
Also could you please share a picture of the front panel of the switch ?
I hope this helps
jsun
 yes I am from Lennar homes. Can I connect the Mac with type c to type c? Or do I need usb to type c.
Imran_ruckus
Community Manager
Community Manager
Hi @jsun
Thank you for contacting RUCKUS Lennar Home Community.
Hope you are doing well!!!
As per the case description, I could understand that your ICX-7150-C12P Switch is not showing connected on the RUCKUS Unleashed system.
As you from a picture you shared, there are lights on PWR and SYST, if there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
First, we will try to reset the Switch as described below:
  • Remove power from the switch.
  • Press and hold the Reset button while applying power to the switch.
  • After all the system LEDs flash amber, release the Reset button.
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE.
i don't think mine was stuck in boot mode, both were green. I am seeing this though when I go into the IP address, any other tips?
it says ICX switch is connecting, and 'unleashed system only supports ICX firmware version 08.0.90 or later'
ICX switch connecting
