Sonos Sub Gen3 pairing issues with Arc and Ruckus Unleased
Awp23
I have been reading a few articles about some of the default settings that Ruckus APs utilize and have been experiencing what appears to be a common problem for those with a similar setup to me where my Sonos Sub won't pair properly with the Arc (I get the Arc +? issue).  I proceeded to login to my master AP with Putty and change some config settings (disabled directed multicast, enabled spanning tree protocol).  I also went onto my router (tp-link wired) and enabled UPnP and IGNP Proxy, but I still get the same issue where my Sub won't stay paired with my Arc.
Am I missing something? Should I reboot my router and my APs and try again?  My sub pairs with the Arc now (which normally it wouldn't even pair on first attempt) but it won't stay paired.  I saw another post where someone with other APs needed to also disable mcast on the ports for the specific AP model, but I tried that and CLI wouldn't let me change port settings for the R510.  Any other ideas or tips (wired ethernet is not an option)?
Thanks!
Anthony
16 REPLIES 16
Sonosspeakers
Hi, I am also having issues connecting the Sonos subwoofer to the Sonos Arc soundbar. I am not tech savy and do not understand most of the acronyms nor where to access my router information. Is there a step-by-step process to solve this issue?
Hi @Sonosspeakers
If you have the same issue, you need to run the same commands, or just wire the sub.
1:Find the IP address of the Master Access Point, this cam be found in the APP, Unleashed Dashboard, or you can use the next guide to discover your network device's IP address.
2:Now you know the IP address, you need to gain remote access to the Master Access Point using any of the next two Application: Putty or Mobaxterm, you can follow up the next guide:
3:You will be requested for credentials which must be the same you used in the Unleashed APP or Dashboard, if you don't know the credential test the next combination:
Username:                      Passwords:
  admin                             sp-admin
                                          Lennar
                                          lennar
                                          ruckus
                                          Ruckus!
                                          Ruckus1
                                          admin
                                          password
4:once you gain access you need to run the next set of commands to disabled Directed Multicast/Broadcast.
Command
Explanation
no qos directed-multicast
This prevents the WLAN from converting multicast traffic to unicast
qos directed-threshold 0
This disables BOTH directed broadcast and directed multicast on the SSID.
If there is only a single client, it will receive broadcast traffic as broadcast and multicast traffic as multicast.
Commands:
>enable
Ap-mode
ruckus(ap-mode)# set qos eth0 directed multicast disable
ruckus(ap-mode)# set qos eth1 directed multicast disable
ruckus(ap-mode)# set qos eth0 igmp disa
ruckus(ap-mode)# set qos eth1 igmp disa
ruckus(ap-mode)# set qos eth1 classification disa
ruckus(ap-mode)# set qos eth0 classification disa
ruckus(ap-mode)#
ruckus(ap-mode)# quit
Yarenis Hernández
