11-21-2024 06:53 AM
My rukus box is keep going in and out after every few mins. Its causing disturbance on Ethernet and wifi both.
11-21-2024 07:51 AM
Hi @Lazarus ,
As per the case description, I understand that your Ruckus setup is not working and are facing intermittent connection issues .
1) Was there any power outage since you started facing the issue?
2) On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
3) May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
11-21-2024 08:10 AM
Q1: No power outage. It start happening after internet provider switch
Q2 and Q3. Pics uploaded. Q3
Q2
Q2
11-21-2024 08:43 AM
Hello @Lazarus ,
To proceed further, we would need to check few configurations of the switch.
To check this, we must identify the ‘current’ IP address assigned by your local router to the switch ICX-7150-C12P
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
Once you login to CLI, please enter the below commands and share the output.
show version
show flash
show inline power
show inline power detail
show interface brief
11-21-2024 09:07 AM
I was able to scan IP but i couldn't figure after that. Can you please remote in and take a look . Its too much techy for me after that
