05-06-2024 12:56 AM
I am running into issue with Rukus ICX-7150-C12P switch when moving from at&t service to a Spectrum service.
I can connect to internet when I am connected to AT&T but when I switch it with the Spectrum Modem, I don’t seem to have internet connection. I have verified that Spectrum service is working by connecting directly to the Modem without the switch. Power cycling both the modem and the switch does not seem to help. I even did a factory reset of the switch by referring the instructions on this forum but that does not seem to change anything. Below are the status lights on the switch and the 2 APs we have connected.
I tried to access the switch using the web browser but the passwords shared on this forum did not work. So I consoled into the switch. Below are screenshots of the status I see. Is the TFTP timeout okay. I am lost on what the issue is. How can I debug this further and resolve this. Your help is much appreciated.
05-06-2024 07:08 AM
Hi @FriscoHm
As per the case description, I understand that your RUCKUS setup is not working after changing the Internet Service Provider (ISP).
If your ISP modem is directly connected to the ICX-7150-C12P Switch, it doesn’t work only with Modem. The connection must be from a Router or Modem-Router combo device. Could you please confirm this once?
Please refer to the short guide link below about how to connect the devices as a reference:
Please check and confirm. Let me know if you have any queries in this regard.
05-06-2024 01:04 AM
I missed mentioning but I can confirm the incoming ethernet connection is connected to the one of the 12 ports. I did not touch the connections on the switch side only swapped the att and spectrum modems on the other end.
05-06-2024 07:08 AM
Hi @FriscoHm
05-06-2024 11:55 AM
😁I get it. Router is required before a switch can connect to the network and that is what I was missing. Added a router and everything is working as expected. Thanks @Imran_ruckus for your help!
05-06-2024 12:03 PM
Hi @FriscoHm
Great!!! Good to know that the issue is now resolved.
Yes, the for Router is responsible to assign IP addresses from it's DHCP server to the connected devices for Internet access.
Have a great day ahead!!!
