12-06-2022 05:50 AM
i have a lennar home, a ruckus switch, 2 APs, and for a week now, we have not been able to get a connection through the switch. lights are on on the APs, the network shows up but once connected, you're offline. it makes no sense. i have no idea what to do, ruckus will not help me, and i need my internet in order to get my job done. as another user said, the "instructions" provided here are way over my head, i think it's ridiculous that it's taking me this long to get the issue resolved, and i still see no end in sight. can anyone help me?
12-07-2022 04:15 PM - edited 12-07-2022 04:18 PM
Hi @relingburg
Please run the next commands to fix the routing code issue, when the switch comes back, or you have time you can upgrade to the code 08095g, however, after running the commands that I will provide the slow connectivity will be fixed.
Commands:
copy flash flash secondary
write memory
Boot system flash primary yes
Example and explanation:
ICX7150-C12 Router>enable
ICX7150-C12 Router>show flash (you can confirm in which partition you have the correct code that will start with SPS example: SPS08080f.bin normally will be your primary partition)
ICX7150-C12 Router#copy flash flash secondary (this will copy what is in your primary code to the secondary)
ICX7150-C12 Router# write memory
ICX7150-C12 Router#show flash (now both partitions must start with the SPS before the code type)
ICX7150-C12 Router#Boot system flash primary yes
Yarenis Hernández
12-07-2022 02:21 PM
here you go!!
i will be waiting patiently by all of the devices for my next step!!!
Hi @relingburg
Commands:
write memory
Yarenis Hernández
12-07-2022 04:26 PM
this is what happened when i went into putty consoled in to the switch and typed the commands, please help with what to try next, thank you
12-07-2022 04:40 PM
Please do this in the following sequence.
Don't add or remove anything.
write memory
Yarenis Hernández
12-07-2022 04:43 PM
after i sent you the last screenshot, i went to your profile and followed the steps in "fix routing code" and i got it to show up as switch instead of router, so i feel like i made some progress?
on my ruckus app, it still shows up red, as icx7150-c12-router, so maybe i didn't make progress. i'll go follow your steps above now.
