04-24-2023 06:39 PM
I've recently noticed that one of my access points will not push out any wifi pass 100mbps, while my other one upstairs shows 1000mbps. I've always called the customer service line and they always increased it back to 1000mbps. How do I increase the speeds without causing any complications? This is causing my downstairs TV's to buffer due to low speeds.
Thank you,
05-04-2023 05:32 PM
05-05-2023 05:45 AM
Hi @Antoniobaker09
Based on your description most possibly your switch starts running the wrong code which we call ‘routing code’ this is a know issue.
You can take Console access to the switch in order to verify, if the switch is able to connect properly to Access Points or if it has a ‘Routing Code’ issue which happens due to power outages most of the time, this is a known issue for Lennar home users.
-MAC address: Physical address of the device this never changes
- An IP address is a unique address (logical) that identifies a device on the internet or a local network like your home (this can change and may not be the same as the one shown on the dashboard)
Please follow the below steps:
Hereby I attach a guide on how to perform an IP scanner on your local network to identify the switch IP address very easily.
2.Once we identify the IP address of the switch proceed to access remotely to the device “Command Line”
ICX7150-C12 Router>
show version
copy flash flash secondary
Example:
I) How to Fix Routing code issues on Lennar Home users via CLI
II) Or WEB access option
Once you are logged in to the ICX-7150-C12P please follow and perform the same commands that are on point '3'
05-05-2023 11:03 AM
Is there anyway you can call me to help me? My computer will not do any of the commands. My number is 318-791-7120.
05-05-2023 11:50 AM
Hi @Antoniobaker09
Effective November’2022, ‘Ruckus Support for Lennar Homes customers will no longer be handled by phone or email.
We will be exclusively supporting customers via this community forum support model.
Please share the screenshot of the error you are getting while troubleshooting the issue.
05-05-2023 12:41 PM
What login should i be using. Admin does not work. Super does not work either.
