04-24-2023 06:39 PM
I've recently noticed that one of my access points will not push out any wifi pass 100mbps, while my other one upstairs shows 1000mbps. I've always called the customer service line and they always increased it back to 1000mbps. How do I increase the speeds without causing any complications? This is causing my downstairs TV's to buffer due to low speeds.
Thank you,
04-25-2023 06:31 AM
Hi @Antoniobaker09
Greetings of the day,
From the case description, it seems you are not able to increase speed beyond 100mbps.
To solve this issue we need to check the speed transferred by the switch ports, so we have to get access to the switch.
There are two ways to get access to the switch.
Hereby I attach a guide on how to perform an IP scanner on your local network to identify the switch IP address very easily.
ICX7150-C12 Router>
2. We have two ways to check the speed transmitted from the Switch to the Access Point.
1- Please share the Screenshots from the Unleashed dashboard as shown in the below picture:
2) Please run the following commands from the CLI of the Switch and share the output of each command-
show version
show inline power
show interface brief
2) By Console access: If access via IP address is not possible here is a guide on how to access to the Switch via console (cable access between your PC to the ICX 7150-C12P) in this case we need a USB type C to USB standard or Console cable Rj45 to USB.
Once you are logged in to the ICX-7150-C12P please perform the same commands and share the output of each command that are on point '2'
04-28-2023 08:35 PM
05-01-2023 06:02 AM
Hi @Antoniobaker09
Thanks for your reply.
Please share the Screenshots from the Unleashed dashboard as shown in the below picture clearly.
05-04-2023 04:47 PM
Is this what you are looking for?
