06-11-2023 11:05 AM
My Ruckus R510 Access Point (AP) has no power.
To date I have:
- Taken down the AP and connected it directly to the Ruckus ICX 7150 POE port. I still had no poer.
- Unplugged the 7150 and plugged it back in. The AP still has no power.
Similar posts in the community included showing screen shots with no background on how or where these screen shots came from andYou Tube videos with no sound. (Note: I played other videos that had sound so it's not my computer's fault).
06-12-2023 08:48 AM
Hi @rhrout
Greetings of the day,
For further troubleshooting please let us know the LED status of the switch using the below guide.
RUCKUS LED Lights
06-13-2023 02:41 PM
This is a photo of my switch.
SYST: Yellow LED.
PWR: Green LED.
No other LED lit.
06-15-2023 06:06 AM
Hi @rhrout
Thanks for the response.
Based on the description it seems that the switch has one green and one yellow light, which means that the switch is stuck in boot mode.
If this step doesn't work, we need to perform a software recovery.
If the resetting process doesn't work, we need to perform a software recovery.
06-23-2023 10:29 AM
All these instructions are confusing to a novice user.
How do you connect a Windows-based laptop with the ICX7150 in order to:
- Upgrade a Switch ICX7150-C12P via TFTP, or
-Upgrade a switch via Web GUI
thanks,
Bob Routier
