05-15-2025 01:10 PM - edited 05-15-2025 01:12 PM
I have a Ruckus switch with one R510 AP. We had some storms a couple nights ago and the internet was not working consistently. I also have lost the password to the Unleashed app, so I wanted to do a hard reset to be able to reset the password and hopefully fix the internet issues. I pressed the factory reset button for 15 seconds and released. Now the AP is not working. The PWR and CTL lights are on and steady, but the 5G and 2.4G lights are not on. I cannot connect to any internet at this time.
05-23-2025 01:53 PM
When I click on https://unleashed.ruckuswireless.com/ it says 'this website can't be reached' (I will attach a screenshot). If I try to find the IP address for the AP on LanScan, I only get one thing that says Ruckus, which is apparently the switch, not the AP. If I try to type in the IP address that is printed on the back of the actual AP, the webpage does nothing. It just "thinks" until it says the site can't be reached. I'm pretty sure that this thing is dead, although the power light is still on.
05-23-2025 03:02 PM
Hello @MandyS ,
I understand that you are unable to connect through the Access points.
Before we can help, we need to check few configurations on the Switch and which version the Switch is currently running.
1. To check this, we must identify the ‘current’ IP address assigned by your local router to the switch ICX-7150-C12P
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
05-24-2025 12:40 PM
Assuming that the one item in my LanScan that says Ruckus is the actual switch, I followed the directions in the Terminal application. I get "connection refused" (I'll post a screenshot). I don't even know what that is supposed to mean. My switch is obviously working since our devices that are plugged into it are still able to get online.
05-24-2025 12:42 PM
05-26-2025 07:21 AM
Hello @MandyS ,
Could you please use the IP address of the Switch to login to the web browser and confirm if you are able to access the Switch dashboard?
You should observe the Switch Dashboard, which should be visible upon accessing the appropriate IP address, as illustrated in the screenshot below.
Please let us know if you are able to access the dashboard with the obtained IP address.
Please login to the Switch dashboard using the default credentials.
These usernames and passwords are key sensitive, please use capital letters where necessary.
