05-15-2025 01:10 PM - edited 05-15-2025 01:12 PM
I have a Ruckus switch with one R510 AP. We had some storms a couple nights ago and the internet was not working consistently. I also have lost the password to the Unleashed app, so I wanted to do a hard reset to be able to reset the password and hopefully fix the internet issues. I pressed the factory reset button for 15 seconds and released. Now the AP is not working. The PWR and CTL lights are on and steady, but the 5G and 2.4G lights are not on. I cannot connect to any internet at this time.
05-15-2025 02:14 PM
Hello @MandyS ,
From the case description, I understand that you are unable to connect through the Access points.
Before we can help, we need to check few configurations on the Switch and which version the Switch is currently running.
1. To check this, we must identify the ‘current’ IP address assigned by your local router to the switch ICX-7150-C12P
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
05-15-2025 03:14 PM
I have the IP address but cannot get past the second step. I do not know the username and password (one of the reasons for the hard reset) This is what I see when I do step 2:
mandysotolongo@Mandys-MBP ~ % ssh [email protected]
Unable to negotiate with 192.168.1.219 port 22: no matching host key type found. Their offer: ssh-rsa
05-16-2025 03:57 AM
This is what I'm seeing in the terminal when I try to "access the command line". Nothing happens, no matter what I try. What am I doing wrong?
Last login: Thu May 15 17:51:04 on ttys000
mandysotolongo@Mandys-MBP ~ % nc 192.168.1.219 23
05-16-2025 04:12 AM
For some reason, the Configure.Me wifi is showing up on my phone and the app says it's connected to the wifi and ready for setup, even though the lights on the AP are not lit up. BUT when I press start in the app, it says the "AP version not supported. Please upgrade your AP" How do I upgrade it when I can't even access it in the app?
