Ruckus Lights/Connectivity
cicibow1
Hi! First off, I am not tech savvy whatsoever, but I am in need of help with my Ruckus WAPs. The issues are below.
1- Both WAPs are showing three green lights and one orange light. I have upgraded the software, rebooted, restarted the access points/switch but it is still the same.
2 - When I do a speed test for the WiFi, it says its great but when connected to the WiFi, it is intermittent and internet does not stay connected. I have had Spectrum come out and check everything and they said everything on their end is good but it's something going on with WAPs. Even when I logon to the app and connected to the WiFi, it doesn't load the app and error comes up saying there is network connectivity issues.
Help please!
1 ACCEPTED SOLUTION
Hi @cicibow1
I hope you can now connect to the Internet via RUCKUS devices without any issues or intermittent connectivity.
Amber/Yellow LEDs on the APs is a normal behavior.
Here is the meaning of each light on the Wireless Access Point so you can use it as reference.
https://docs.commscope.com/bundle/unleashed-200.14-onlinehelp/page/GUID-19D4261B-D10B-4DE3-B63A-3498...
Yellows light 2.4G: The radio is up, no clients are connected to the 2.4 GHz radio.
Yellows light 5G: Radio is up, no clients are connected to the 5 GHz radio.
So, if there is a device (iPhone) that is using the 5G radio, the light on the Access Point will be turning green on the 5G radio indicating that there is a client/device using that radio (5G)
I hope that makes it clear for you.
46 REPLIES 46
Hello @cicibow1 ,
I would request you to please perform .an IP scan and share the screenshot of the results.
After you review the IP addresses, can you please delete the message so the public will not see it.
cicibow1
An update on this? I would like to get this fixed before my new internet installation on Friday.
