Ruckus ISC 7150 C12P not powering access points after power outage
ClemTigers
We had a recent power outage and the access point within the home are not working. In the past I have been able to power reset these systems and they reboot effectively. This time this has not worked and it seems that my Ruckus system is stuck in boot mode with an orange light for SYST and a green light for power.
I have spent a couple days looking over similar posts about this topic and have tried resetting the device and have installed the drives, upgrade, putty, MobaXterm, and other things. None of these seems to work at all and have just led to me wasting hours.
The issue with the rest and that all the lights flash orange for hours and nothing actually happpens.
The issue with doing these putty and MobaXterm and they both require the system to put in a "com" from the "ports." I have used three different computers and both the ethernet and the USB C connections and none of them have this COM show up in any circumstance.
Can someone please explain to me how to get this device out of boot mode and working. Please do not refer me to another post I have looked over the other posts on this form and it has not led to any success.
1 ACCEPTED SOLUTION
Hi @ClemTigers
Thank you for the response and for sharing the requested information.
This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
Kind regards,
Sofia Gätjens
9 REPLIES 9
Hi @ClemTigers
Have you tried different Type-C cables?  Did you install the drivers? Have you tried use a different laptop?
Kind regards,
Sofia Gätjens
I have tried one Type - C to USB and one Type C to Type C. I have tried ethernet. I have tried both, I have tried both on two different computers.
Hi @ClemTigers
Could you please plug your ICX-7150-C12P Switch into a working power outlet and send us PICTURES of it showing the light status, and cord connected to the Switch and power outlet? Please refer to the below pictures as an example.
Kind regards,
Sofia Gätjens
Note the router that is working is plugged into the same outlet.
Hi @ClemTigers
Kind regards,
Sofia Gätjens
