Ruckus ICX 7150 not powering on all of sudden after a power shutdown in the community
sebastso
   We tried all the suggestions including : https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Upgrade-a-Switch-ICX-...
and tried upgrading firmware.
The steps were completed successfully (though I could see lots of crash messages on the console), still, the device only has 2 lights as shown in picture and wifi extender does not power on.1.jpeg2.jpeg3.jpeg
22 REPLIES 22
Hi @sebastso
Based on the information you have shared it seems like the software recovery process was not done correctly. So please try to follow the steps using the below guide and let us know the result.
Also to solve this issue you need download and copy the files to the folder correctly.
Once you are done with the above steps please share the output of the below commands.
saveenv"
“ping 192.168.0.2”
@Jayavidhya, what do you mean not done correctly? The ping is successful , but not always, sometimes it says successful ping, but when we give the command update_primary, we can see
Loading: # T T T T # # TT
retry Count Exceeded, starting again
Primary image download failed
tftp_failing2.jpegWe can also see TFTP Dialog opening up & starts sending bytes (see sceenshot), saying 80740 bytes sent. We followed the exact steps in the article you just gave. Please see the screenshot properly.  It has the TFTP Dialog & console output, you can see the data transfer fails.  At the end it says, Primary image download failed. We're stuck here, it does not move forward, we tried multiple times. Same result.
Hi @sebastso
Based on the images you have shared it seems like the files were not downloaded properly. Please follow the steps correctly and let us know the result.
Also please share the screenshot of the image showing ping successful message.
saveenv"
“ping 192.168.0.2”
Hi @sebastso
Thanks for your response.
To complete software recovery process please enter the following commands and let us know the results.
“setenv image_name SPS08090k.bin”                                        (enter the correct image file name)
 “update_primary”                                                           (upload the image on the primary partition)
“update_secondary”                                                           (upload the image on the secondary partition)
*Wait that loads the image and continue with the boot:
 “setenv uboot mnz10115.bin”                                                    (enter the correct boot file name)
 “update_uboot”        (upload the boot code)
* Wait that loads the boot and continue with the Final command reset:
“reset”             (finally enter reset to reload the unit)
Tutorial video: https://www.youtube.com/watch?v=RHriOYYD_iI
Hi @sebastso
