07-17-2023 05:36 AM
Our ICX 7150-C12P died yesterday. All of the WAPs connected via PoE to this unit do not have power either. This happened a couple weeks ago and the issue was resolved by cycling the power off and on. However, it is not working this time. When I cycle the off and on now, the green lights will blink one time and remain off. No data lights or any other lights come on after that. There's a post that has the same exact issue I have posted here: https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Ruckus-ICX-7150-C12P-does-no...
This post also shows exactly what my unit does when I plug it in here: https://gfycat.com/coolflimsybushbaby
Please help.
07-17-2023 01:22 PM
Hi @LarryN
Based on the images you have shared also the troubleshooting steps you have done, it seems to be the unit is totally dead, this unit should be RMA (return merchandise authorization) in simple words replace it.
Feel free to contact us via chat, comment you already have a post, copy the link from the post (URL) and paste it into the chat to start unit replacement.
07-17-2023 06:50 AM
Hi @LarryN
Greetings of the day,
- Please let us know the LED status of the switch and the access points using the below guide.
R510 LED lights
RUCKUS LED lights
07-17-2023 06:56 AM
Hello @Jayavidhya,
All LED lights on the switch and all 3 WAPs are off/black.
07-17-2023 07:33 AM
Hi @LarryN
Thanks for your response.
Please share the image of the switch and the access points showing the LED status.
Also make sure the cable is actually connected to the ICX-7150-C12P ( Switch ) In one of the 12 ports in the middle
Make sure the cable is in good condition so that both ends and connectors look good.
Here I will leave a short guide how to connect the devices properly :
07-17-2023 08:05 AM
Here are the pictures. Please note that this setup/configuration (cables, etc.) have remained untouched and unchanged since Lennar’s original install.
Front
Connection - No Lights
Lower Level WAP
Middle Level WAP
Upper Level WAP
Larry
