Ruckus ICX 7150-C12P not sending power to R510 AP' after o power outage
jadelamain
hello
I am trying to solve the problem by recovering the software after reset the ruckus.... green ligths on syst and pwr... I ALREADY INSTALLED PUTTY... i HAVE THE FILES BOOT AND IMAGE ON MY COMPUTER...wHAT i HAVE TO DO NOW?
5 REPLIES 5
Hi @jadelamain
Based on your description, it seems that the switch is stuck in boot mode.
Note: after fixing the issue of the Switch been stuck in boot mode, please perform an upgrade to the code 08095g UFI and upgrade both partitions with the switching code file named SPS08095gufi.bin, so perform the software recovery using the code 08090k with the upgrade image file named SPS08090k.bin, then when the switch is back to normal upgrade to the file SPS08095gufi.bin for both partitions primary and secondary.
It was not necessary... I just saw on youtube how to config powerlines in a range of ports...
The power was off on all off them. After config its ok and working well. I checked using the comand show powerline.
Dhill1015
What sight did you go to allowing you the steps to fix this issue.  I'm running into the same issue.  I have been trying to switch the com ports and have been unsuccessful.  What steps did you do in order to fix your Ruckus?
Hi @jadelamain
As you mentioned, the SYST and PWR lights are steady green, which means the lights are in a normal state.
Since the switch is in the normal state you can take Console access to the switch in order to verify, if the switch is able to transfer the power to PoE devices via 12 ports.
To check this, first, we have to get access to the switch, and there are two ways to get access to the switch.
  1. I) By IP Address of the Switch OR
  2. II) By Console Access to the Switch
  1. By IP address: To fix this issue, we must identify the ‘current’ IP address assigned by your local router to the switch ICX-7150-C12P
ICX7150-C12 Router>
  1. Now please perform the following commands and share the output:
Show version
Show inline power
Show inline power detail
  1. By Console access: If access via IP address is not possible here is a guide on how to access to the Switch via console (cable access between your PC to the ICX 7150-C12P) in this case we need a USB type C to USB standard or Console cable Rj45 to USB.
Once you are logged in to the ICX-7150-C12P please follow up the same steps that are on point '2'
