04-24-2025 06:11 AM
Imran hope all is well, was wondering if you can guide me or help me with my Ruckus APs, My network provider is ATT and the Internet from the router Wi-Fi/Ethernet works well, cable from router to Ruckus switch is good as well, I see the AP Internet appear on my devices but I can't even connect to it, I don't even get the "connected without Internet" either. Reset both the power to my ATT network router and Ruckus switch and nothing. I see different lights turned on my 2 devices on the ceiling of the first and second floors.
04-28-2025 05:51 AM
Hi @HialeahGomez
Glad to know that the issue is now resolved.
Thank you again for contacting RUCKUS Lennar Home Community, and feel free to contact us for future queries.
Have a great day ahead!!!
04-24-2025 06:52 AM
Hi @HialeahGomez
Based on the information provided, it appears that you are unable to connect to the Internet via RUCKUS devices.
As per your explanation and the pictures, your devices seem in a normal state.
Could you please verify Internet connectivity via the RUCKUS ICX-7150-C12P Switch using an Ethernet cable connected to any 1 in-12 ports and the Switch and the Laptop? (Refer to the screenshot below)
Let me know if your Laptop gets Internet connectivity using an ethernet cable.
04-24-2025 09:47 AM
yes is can confirm the speed test from Ruckus Ethernet was 360mps and working
04-24-2025 09:54 AM
Hi @Lsil123
Please try the steps below.
- Log in to your Unleashed system using the Master AP IP Address or visit https://unleashed.ruckuswireless.com/
If you encounter difficulties accessing the above link or if you are unsure of the IP Address of your Access Points, please refer to our guide on finding the IP Address of the Access Point:
You should see the below-Unleashed dashboard after finding the IP Address of the AP. Try to log in
Let me know if you can log into the Unleashed dashboard shown in the above screenshot.
04-28-2025 05:24 AM
Hi @HialeahGomez
Thank you.
