Reset 7150, lost connection with AP r510
AliT
I factory reset my ruckus 7150. I have a sticker on it that gives from Lennar wifi name and password and admin name and password. The APs are now broadcasting Recover.me-xxxxx. I think I need to log into the AP and turn off mesh? What is the password? I tried ruckus-admin, ruckus-Lennar, the serial number,  and ruckus-<serial number>. I can't figure out the password,  is it based on the connected 7150 at all? I don't know what ruckus-<password> means when I read through this forum.
1 ACCEPTED SOLUTION
AliT
I'm not really sure how I got it working, but I did, ha. I configured it over my laptop and the WLAN I created finally showed up, and I see both APs and both are transmitting data. Whew. Thanks for the help and quick responses!
11 REPLIES 11
AliT
Status of ruckus 7150 (no internet connected yet) green light stat, green light syst, green light power, green light on port that my r510 is hardwired to
AliT
Since I reset the switch, do I have to log into it to configure the APs or can I set up the APs from the AP connection? Ap is still broadcasting recover.me and I can't get it. But I now have internet connection working.
AliT
And how do I figure out the ip address of the switch? Do I have to telnet in or is there a gui?
Valued Contributor III
Hi @AliT
Based on your description the recover.me appears only when a mesh configuration is present.
To solve this issue we need to hard reset the access points to configure the network again.
Please try to reset the Access point by holding the reset button until you see the configure.me SSID.
For detailed understanding of the issue please refer to the below guide.
https://support.ruckuswireless.com/articles/000011009
Also to locate the IP address of the switch please refer the following guide.
AliT
Hi, thanks so much for your help. Small step closer to success. OK hard reset the AP and got to configure me. FYI, when I do the IP address https://www.advanced-ip-scanner.com/ I see that 192.168.1.4 is labeled at Ruckus Wireless and it is the MAC of my 7150. I dont actually see another Ruckuss device (shouldnt I see my AP?)
I connect to the Configure.Me-xxxx, and connect via the unleashed mobile app. I go through custom install
Automatic DHCP Master IP Address 192.168.0.1 (is this right?)
Mesh Option disabled
I set my new WLAN name, and WLAN password
Admin username and password ( I set this to my own admin password, should this be from the default that Lennar gave me, even though I reset the 7150? )
Set the recovery question and email, and then press submit.
I don't see the WLAN/SSID that I created. I still see Configure.me-xxxx not the WLAN I created. I did disable Private DNS. And now I can't connect to the Confiture.Me-xxxx that i had just used. What am I doing wrong? Am I supposed to use the admin creds for the 7150?
