R510 no power, trying to do initial setup with Verizon router and not able to
KColeman
I recently moved into a Lennar home and am trying to connect the wifi. After looking at the setup guide, I have an issue with the R510 not powering on for connection. Please advise.
23 REPLIES 23
Imran_ruckus
Hi @KColeman
Hope you are doing well!!!
As per the case description, I could understand that you need assistance in re-setting your RUCKUS set up in a recently moved Lennar Home. And you see the RUCKUS R510 Access Points are not powered ON.
1. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
2. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
3. May I know how many R510 Access Points are connected to the RUCKUS ICX-7150-C12P Switch?
KColeman
2. Yes, the internet connection from the Internet Service Provider (ISP) is stable and working.
3. 2 R510 Access Points are connected to the RUCKUS ICX-7150-C12P Switch.
Hi @KColeman
As I can see from the picture you shared, there are lights on PWR and SYST, if there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
First, we will try to reset the Switch as described below:
  • Remove power from the switch.
  • Press and hold the Reset button while applying power to the switch.
  • After all the system LEDs flash amber, release the Reset button.
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE.
KColeman
I've done the reset. The lights are green. How do I connect it now?IMG_3074.jpeg
