R510 has no power
Dhill1015
Having issues, not getting power to to my R510. Ive pushed the reset button for 30sec and unplugged from power source.  David Hill
12 REPLIES 12
Hi @Dhill1015
Will no, by default, the new code enable PoE, however there is a possibility that is no enable, so please follow up the next steps.
1:If you gain access via CLI, please run the next command and share it with us.
show lldp neighbor
show inline power
show poe
2:If you gain access via WEB GUI, Please share the next screen.
port>inline power>inline power statistics
Yarenis Hernández
Dhill1015
Just a refresher, my problem lyes with no power to my Ruckus nor do I have power to my 510 in the ceiling.  I'm ready to pick this back up to fix this issue.  Please stay with me limiting the length of time between our messages.  With the steps I have followed, I'm stuck on Com ports.  My system shows com5 when I go into Putty it won't allow me to change the com.  Suggestions?
Dhill1015
Still need help to fix this problem.
Valued Contributor III
Hi @Dhill1015
Please confirm the LED light status of your R510 Access points.
R510 LED lights
PWR:
2.4g:
5G:
Dhill1015
 As you can see no lights on the R510.  Nor are there lights on the Ruckus 7150 in the closet.
