10-01-2023 06:09 PM
I have no username and password from previous owner. I have Xfinity (X1) Gateway but unable to connect to Ruckus
10-04-2023 04:37 PM
yellow is line from Xfinity X1 and blue one is from AP that was reset
10-04-2023 04:57 PM
Hi @sampande
Could you please unplug and plug all the ethernet cables connected to the Switch into any of the 12 ports as highlighted in the below screenshot? Once you plug into other ports, please reboot (unplug and plug from the power outlet) your RUCKUS ICX-7150-C12P Switch once.
Please check the Internet connectivity after reboot and let me know if you have any queries in this regard.
10-04-2023 11:26 PM
Also after restarting the Ruckus switch panel, I noticed that green light on 2 APs are flashing green while 1AP (which I reset earlier) was not on - this is all on Panel.
Secondly, I tested Internet at LAN in bedroom and its working fine that means it issue with APs, may redo the process with some other AP (total there are 3 APs)
10-05-2023 08:15 AM
Hi @sampande
Yes, please repeat the factory reset with another Access Point.
Please note, as you have 3 Access Points in your setup, remove the cables of the other TWO Access Points, and perform the factory reset on the ONE connected access point. Once you complete it, connect the unplugged Access point cables back to the Switch ports and they will sync up with the configurations from the factory reset Access Point.
Please perform the factory reset using a Laptop as described in the below VIDEO:
Ruckus Unleashed Set-up using Web browser:
10-06-2023 01:27 PM
Hi Imran, after resetting another AP, 2 out of 3 APs are working now. Still one AP is having the problem. It’s not showing any light at the Switch Panel.
please help.
thank you
