08-19-2025 07:49 PM
No power to the box. No success after trying numerous reset attempts.
08-20-2025 06:28 AM
Hi @coolcardo ,
From the case description, I understand that your RUCKUS Switch is not turning on even after performing multiple resets.
08-20-2025 04:31 PM - edited 08-20-2025 04:32 PM
Video has been uploaded. As you’ll see, when I plug in the power chord into an outlet it quickly turns on (Green lights) show for a second then goes off. I used an extension chord to try other outlets but yielded the same result. The primary outlet has power because other devices are plugged into the power strip and those too were tested with no power issues.
08-21-2025 06:18 AM
Hi @coolcardo ,
Thank you for sharing the requested VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up even after connecting it to working power outlet, and when plugged in, all lights are off. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
