01-07-2023 12:46 PM
Contacted Samsung smartthings, thinking it was a Smartthings issue. Ran diagnosis with system by resetting, power off / on, then direct cable to Smartthings instead of Ruckus and all appliances worked. Contacted Lutron, did the same thing to isolate the issue. It appears several of my neighbors who have the same product (Lennar home) all have had the same issue with their Ruckus and Ruckus replaced their product.
When products are routed through Ruckus, nothing is working - all appliances are offline. When plugged direct (without Ruckus) products work.
Any assistance in getting this resolved to get my Lennar Smart Home back to being a smart home would be appreciated.
01-10-2023 07:13 AM
I will be testing these options tonight... I will advise my findings.
01-16-2023 06:47 PM - edited 01-16-2023 06:48 PM
All of your "solutions" still did not solve the issue - because they were not the right solutions for my issue.
However, what did solve the issue is a $100 purchase from Amazon (not a Ruckus product) that included tech support. Ironically, it was Lennar that pointed me to this product when I TALKED to them. I plugged it in, plugged in all the hubs and everything is back working (10 minutes). The best part is I called the tech support line, and a person answered and walked me through the easy connection process. All of the hubs in my Lennar home is working perfectly.
It was a simple and cheap solution. It is unfortunate about the frustration and wasted time Ruckus caused me, but lesson learned. When there is a community forum and this many people complaining about the same issue, beware.
Now this post can be marked as the solution. Simply put save yourself time and frustration buy another product, not Ruckus.
01-10-2023 07:13 AM
01-11-2023 04:55 AM
Hi @HN2023
Sure, Please let us know once you have tried all the troubleshooting steps.
01-13-2023 12:40 PM
Just FYI.... I did not mark this as a solution. It was intended as a response not a solution to my issue.
The issue is still outstanding, and the box still does not work. For someone who does not have a technical background this is a difficult forum for solutions and help.
01-13-2023 03:24 PM
Hi @HN2023
Could please provide a picture/panoramic photo, showing the switch is connected to a power source/outlet and the lights
Note : Before uploading the photos please login to the RUCKUS account and you can upload the image.
Best Regards
Fernando Vasquez
