No power access point
Tony
Can i buy something instead of ruckus tired of going through this every time there is a power surge
9 REPLIES 9
Tony
no go still not working
Imran_ruckus
Community Manager
Community Manager
Hello @Tony
Thank you for your response and for providing the update.
To address the issue with the RUCKUS ICX-7150-C12P Switch PoE (Power over Ethernet) ports being disabled, resulting in the Access Points not receiving power, I recommend following the steps outlined in the RUCKUS Lennar Knowledge Base self-help article. You can find detailed instructions on resolving this issue at the following link:
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/NO-Power-on-Access-Points-an...
Based on the output you provided previously, it appears that your switch is currently running on an older version (08.0.61a non-UFI), which may be causing the recurring issues.
This issue may be repeated in the future to avoid the same, as advised in my previous post, I recommend upgrading your switch to a recommended UFI version. You can find detailed instructions on how to perform this upgrade in the RUCKUS Lennar Knowledge Base self-help article available here:
Since you have access to the CLI, I suggest following the second upgrade option outlined in the article.
Please proceed with the upgrade process and feel free to reach out if you encounter any difficulties or have further questions.
Imran_ruckus
Community Manager
Community Manager
Hi @Tony
Thank you.
Imran_ruckus
Community Manager
Community Manager
Hi @Tony
Thank you.
Imran_ruckus
Community Manager
Community Manager
Hi @Tony
Thank you.
