Need help!
Aromero
Need help, having problems with switch/APs after power outage, has not been the same since.
13 REPLIES 13
I’m logged in
Hi @Aromero
Please follow the below screenshot and enable Telnet:
Once you enable Telnet try to access CLI from the MAC terminal as described below. And share the output of the commands mentioned below in this post.
If you have a MAC device, please try the below process.
Example "open terminal":
Telnet: Example
nc 10.0.0.132 23 (Format is : nc <ip address of the switch> 23)
show version
show flash
My switch was showing disconnected due to no IP address. I entered the “ruckus-unleashed” IP address as found on my xfinty portal. Has been stuck on “ICX switch is connecting” for the last 20 minutes.
There is a another IP adresss I tried entering related to “ICX7150-C12-Router” as also found on xfinity portal. That IP address notified me invalid rather or could not find/ping.
Hi @Aromero
Please let me know if you can see the Switch dashboard as shown in my previous post? (Mentioned once again below)
Please confirm.
Thank you again for your patience and understanding
