Need Help – Lennar Home ICX 7150 + Two APs (Configure.Me and Recover.Me) – Internet Not Working
zsl666
I live in a Lennar home that came with a Ruckus ICX 7150-C12P switch and two Ruckus APs. I’m having trouble getting my network working again after trying to set up the second AP.
Current situation:
  • AP #1: Shows as Configure.Me-XXXXXX. I can connect to it and access the Unleashed setup page, but it says Internet: Disconnected, Ethernet: X, DNS: Unreachable. It does have an IP and Gateway, but no actual internet connectivity.
  • AP #2: Shows as Recover.Me-XXXXXX, which I understand means it is in recovery mode.
  • ICX 7150 switch is connected to my ISP router via the orange Ethernet cable, AP cables are in PoE ports. I tried moving the uplink cable to port 1/1/1 and rebooted both switch and APs, but still no internet.
  • I have already factory reset the Configure.Me AP and gone through the setup wizard.
What I’ve tried so far:
  1. Factory reset AP #1 and created a new Unleashed network.
  2. Reconnected cables with uplink from router to ICX uplink port (port 1/1/1).
  3. Rebooted switch and AP multiple times.
  4. Checked IP/DNS settings in Unleashed (set to DHCP).
What I need help with:
  • Why is my Configure.Me AP getting IP/Gateway but failing Ethernet/DNS checks?
  • How can I properly configure my ICX 7150 ports for uplink and AP connections?
  • Steps to recover the Recover.Me AP so it can join the network.
Any guidance, example configs, or troubleshooting steps would be greatly appreciated!
Thank you in advance.
31 REPLIES 31
I performed reset on the 1st ap. and then re-setup the 1st ap. And then I try to connect 2nd ap, the 2nd ap didn't synchronizes. It still shown as configure.me. I also login to the Unleashed dashboard, but I can only see 1 ap connected.
pinky_ruckus
Valued Contributor III
Hello @zsl666  ,
I understand that you are unable to get the AP version details from the individual Access points.
I would request you to please refer to the below mentioned screenshot to get the AP version details:
Hi, Please see the screen shot. I can only see one AP in the system. The 2nd ap is connected and still shown as configure.me. Please let me know do I need upgrade the ap system.'
Thank you
pinky_ruckus
Hello @Masni ,
From the response you shared, we understand that your RUCKUS Access Points are on an older version which doesn’t let you manage them. We suggest you upgrade your  RUCKUS R510 Access Point to version 200.15.6.212.27 which is recently released.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to upgrade the Ruckus AP to a recommended version 200.15.6.212.27
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/Upgrade-process-of-the-RUCKU...
We would request you to please select the option “Local upgrade”.
Please click on Local upgrade and you can upgrade the version to the recommended version 200.15.6.212.27.
pinky_ruckus
Hello @zsl666 ,
