My Smart home system is not working such as no doorbell
Ariel2023
My Smart home system is not working such as no doorbell (ring) but Ruckus unit has green lights. I need help please. thank you
26 REPLIES 26
Hi @Dar
Thank you for the response and for sharing the requested information.
This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
Kind regards,
Sofia Gätjens
Hello Sofia.
Thank you very much for your help. Now the ceiling unit has powered up. But I still don’t have the doorbell working. Is there specific port for the doorbell that missed when I disconnected them from old and connected to the new Ruckus Switch?
Hi @Ariel2023
Please always use the 12 ports in the front to connect devices.
If you encounter ongoing issues after connecting the doorbell to any of these ports, my recommendation would be to inspect and, if necessary, replace the cable.
Kind regards,
Sofia Gätjens
Thank you for this information.
what does it mean if port #1 only has orange light but port #3 next to it has green lights? Thanks
Also, what is the proper or safest way to disconnect the lines including the power and reconnect them? Thank you
