04-17-2023 07:31 AM
My Ruckus wireless router seems to have stopped connecting to any website - Reset etc doesn't work. I put the device off for 5 mins, didn't help. I hit the reset button, didn't help. The verizon modem connects to the internet just fine - all the problem is at the Ruckus router.
04-24-2023 10:58 AM
Hi @sramakrishna26
Greetings of the day!!!
Thank you for the response and update.
Great!!! Good to know that the issue is now fixed.
Have a great day ahead!!!
Lennar Home Community.
04-24-2023 10:58 AM
Hi @sramakrishna26
06-02-2023 05:20 PM
Hello
Most of the services were disabled in the Ruckus console. After enabling the internet works as expected from the Ruckus wifi name. Is this the correct fix?
Regards
Saravanan
06-05-2023 08:09 AM
Hi @geethasaravanan
Hope you are doing well
As this case is raised by @sramakrishna26 and it is now closed.
To avoid confusion with the posts, please post these details on your own post so that we can guide you properly.
05-01-2023 05:26 PM
Hi - I am having a similar issue. I followed the similar steps using PuTTY.
1. I get an unexpected request to log in as but have been able to bypass it.
2. I get the CLI and can enter the command enable, but the commands "show version" and "show flash" are not recognized.
3. I have updated the FW (200.14.6.1.179) which showed initial success, but the issue of the internet dropping continues. I have confirmed by login into to the WAP using the browser.
4. Should I run restore factory settings via the web?
05-01-2023 05:34 PM
For the unexpected login prompt with Putty, the agent asked me to use Telnet. It worked - no login necessary.
