Log in and connection issue
Hidi1982
I haven't been able to log in on the app because it says I'm not connected to the network. I'm not able to reset my password. It gives me this message
"Password recovery is disabled
Please setup your password recovery configuration firstly"
I tried logging in on the website and resetting my password however it is not letting me move forward.
My wifi still works. The APs light are green. I just can't manage my network and there is only one log in destination on there.
Do you have any suggestions? Do I need to start the whole process of configuring/setting up the network over just like the first time?
2 ACCEPTED SOLUTIONS
Imran_ruckus
Community Manager
Community Manager
Hi @Hidi1982
Hope you are doing well!!!
As per the case description, I understand that you are unable to log into the RUCKUS Unleashed application. The Wi-Fi network through the RUCKUS Access Points just works fine.
This is a known issue when your RUCKUS Access Points are on an older version which doesn’t let you log into the Unleashed application. To assist you in upgrading your RUCKUS Access Points please help us with the below details.
Please log in to your Unleashed system on a LAPTOP WEB BROWSER using the Master AP IP Address OR https://unleashed.ruckuswireless.com/ ? Please check the current version of your Unleashed Access Points and share a screenshot of the same.
Please make sure you are connected to the RUCKUS Wi-Fi Network to access the same.
If you can’t access using the above link and don’t know the IP Address of the Access Points. Please refer to the below guide to find the IP Address of the Access Point to get the requested information.
You should see the below-Unleashed dashboard after finding the IP Address of the AP. Try to log in
Please check, and help us with the above-requested information, since we can upgrade the APs to avoid this issue, and let me know if you have any queries in this regard.
Hi, I was able to log back in the app through my social media google account using my IP address as a login destination location. I then upgraded the APs to version 200.14. Thank you!
36 REPLIES 36
I can see the test response
pinky_ruckus
Valued Contributor III
Hello @inkmark ,
Could you please share the screenshots that I have requested in the previous post?
Could you please log in to your Unleashed system on a LAPTOP WEB BROWSER using the   AP IP Address OR https://unleashed.ruckuswireless.com/ ?
Try to login.
Please refer to the below screenshot for more information on how to know your Unleashed Access Points version details.
pinky_ruckus
Hello @inkmark ,
pinky_ruckus
Hello @inkmark ,
Here are the screens you requested again. They are still not connecting like earlier screen shots. CleanShot 2025-09-09 at 09.31.59@2x.pngCleanShot 2025-09-09 at 09.38.16@2x.pngCleanShot 2025-09-09 at 09.32.47@2x.pngCleanShot 2025-09-09 at 09.32.35@2x.png
