Lennar woes - stuck in routing
Kevind
I have a ICX-7150 that’s stuck in routing mode and I need to get it into the switch code so I can upgrade it however I can’t serial connect to it and can’t locate an IP for the device. Any suggestions?
14 REPLIES 14
Kevind
Well i got access to it after following another document and resetting the username process but now how do I get into managing the AP's..? All I have is this terrible UICapture.PNG
pinky_ruckus
Valued Contributor III
Hello @Kevind ,
I understand that you are trying to manage your Access points, we use a system called Unleashed to manage the APs or the Switch.
We would require the IP address of the AP to login to the Unleashed interface through browser,
I will leave you a guide on how to perform an IP scanner on your local network to identify the AP IP address very easily.
Could you please log in to your Unleashed system on a LAPTOP WEB BROWSER using the Master AP IP Address OR https://unleashed.ruckuswireless.com/ ?
Please make sure you are connected to the RUCKUS Wi-Fi Network to access the same.
You should see the below-Unleashed dashboard after finding the IP Address of the AP. Try to log in
Once you see the above dashboard, please try to use the default combination credentials as mentioned below.
Please check and confirm and let me know if you have any queries in this regard.
pinky_ruckus
Hello @Kevind  ,
pinky_ruckus
Hello @Kevind ,
pinky_ruckus
Hi @Kevind ,
Thank you.
