11-22-2022 07:29 AM
Hi, I have been dealing with slow wifi for a while now. The system came with Lennar home. I tried to reset everything but that didn’t help.
Any suggestions on what i should do? Thanks
12-08-2022 04:26 AM
Hi @DeanT
Could you please sent me the following command :
Show version
That the WiFi is unstable, the only problem that would cause it would be the 'routing code', but Ruckus only distributes internet from the ISP, the next step would be to check the ISP (internet connection)
Best Regards
Fernando Vasquez
12-09-2022 04:43 AM
I used a different wifi modem and wifi is running good.
SSH@ICX7150-C12-Switch#show ver
UNIT 1: compiled on Aug 26 2022 at 01:20:24 labeled as SPS08095h
(31457280 bytes) from Secondary SPS08095h.bin (UFI)
SW: Version 08.0.95hT211
Compressed Secondary Boot Code size = 786944, Version:10.1.25T225 (mnz10125)
Compiled on Mon Aug 8 11:58:28 2022
HW: Stackable ICX7150-C12-POE
Serial #:FEK3833R0BL
Current License: 2X1G
8 MB boot flash memory
2 GB code flash memory
1 GB DRAM
--More--, next page: Space, next line: Return key, quit: Control-c
12-09-2022 05:25 AM
Hi @DeanT
Please check the wired are in good conditions.
Great ! There are some settings on wireless to improved the network for example create a dedicated network 5G only for smart devices like iphone/PCs / Macs .
Creating a New Wireless WLAN (SSID)
How to improve your 2.4 GHz signal
Best Regards
Fernando Vasquez
12-09-2022 05:41 PM
Would factory reset the Access Points help?
can it be a defect product?
