05-28-2024 02:58 PM
I have Lennar Ruckus system installed. I am getting Intermittent and slow connection, some device working and some taking forever to load connection. sometime i am getting socket error. Please suggest how can i fix?
i got switch and access points installed in my home from Ruckus
05-31-2024 02:01 PM
Hi @mp2025
Thank you for your response and for sharing the information.
It appears that the issue may stem from an older non-UFI version (08080d) on your RUCKUS ICX-7150-C12P Switch. To address this, I recommend upgrading your Switch to the recommended UFI version (08095g).
For detailed guidance on the upgrade process, please refer to the RUCKUS Lennar Knowledge Base self-help article provided below:
PLEASE NOTE: Since you are using a Macbook, I advise opting for option-1 from the aforementioned article, which involves using a USB/flash drive. Ensure that the drive is formatted in FAT32 and is a STANDARD A USB.
Once you initiate the upgrade process on the Switch, please feel free to reach out if you encounter any difficulties or require further assistance.
06-05-2024 07:16 AM
Hi @mp2025
Your prompt response would be greatly appreciated.
Thank you for your attention to this matter.
06-07-2024 01:58 PM
Hi @mp2025
06-11-2024 05:57 AM
Hi @mp2025
